rear end ratio tag???HELP???
timberlan99
Member
richmond county NC
How do i find out what ratio I have in my 89 wrangler I cant make since of the tag and the ring has 30 teeth and the pinion has 11 thats 3.65 that doesnt sound right either the tag number is below if you can help me I would greatly appriceate it...
53004684
55 605295-6
:confused:
53004684
55 605295-6
:confused:
I come up with 2.73 with that tooth count. Are your sure you counted correctly?
The Expert DanaMATE.Com Contact Us Search
Enter Bill of Material Number or use the drop downs below.
Bill of Material #:
Select a Make: Select Year: Select Model and Model #:
Select Make CHRY FORD GM JEEP
Found -> 1
JEEP Model 35 REAR 1987 - 1989 YJ
Bill of Material Diff. Type Ratio Ring and Pinion Kit Differential Assy Kit Differential Case Kit Diff Inner Parts Kit Right Hand Shaft Assembly Left Hand Shaft Assembly Change Ratio
605295-6 STD 3.55 707244-3X 74209X 43218 707247X 72912-1X 72912-2X Change...
If it is a 4.2 and 5 speed it is normally 3.07 or 3.55. Did you check both diffs for a tag.
x2, the best way to check is count the teeth and correctly do the math...30 / 11 = 2.73
Now, I didnt think that ratio apeared in YJ's...are you sure this R&P are out of that YJ? If you told me it was a 89 YJ 4.0L 5 speed, I would have said 3.07
hey
you divide the drive into the driven. I just did and go 0.366667 so 3.65 3.66 should be right by your calculations. Trust me I'm a professional. Now If you tooth count is right thats your ratio, just remember you divide drive (pinion) into driven (ring).
:fuck-you: I was about to say the same thing!
