Rear led flasher issue
**89mightymax**
taylorsville
I have a 86' Toyota pickup. I put a flatbed on it with all led tail lights. Everything works except for the flashers. With the stock relay the stay on solid and the relay buzzes. Bought a ep35 relay for led lighting 2-4 lights and nothing happens. Any help would be appreciated.
Lights are wired right. And for some reason there is a extra green wire on both sides. Both tail lights worked fine before the swap. I might go through it again with a wire diagram and make sure. If I can find one
86-powered by switch
85-ground
87-lights
30-fused power constant.
The extra green wires are for your turn signals. Not to complicate things even more but you may want to look into this:
http://www.amazon.com/gp/aw/d/B0008G1NNY?pc_redir=1411189949&robot_redir=1
I used one on my buggy and it makes it a lot easier combining all the electric signals into a three wire.
