Make sure the lip of the seal is facing forward. Torque is 85 ft/lbs on the main cap bolts. Also, put a thin bead of silicone on top of the cap where it sits against the block to seal that area too.
I've done so many over the years without any comebacks. Just take your time and don't damage the crank when removing/installing the seal.
I just put one on and it wasn't bad at all. top seal came out easy just used a screw driver to push it out. bottom seal was a pain though but it finally came out
