Dawnpatrol
Jesse Higgins
- Apr 25, 2016
- Raleigh
I recently installed a SYE and waggy springs (SUA) on my YJ. Now I'm thinking I need to dial in my pinion angle due to the new SYE. From a visual standpoint it looks like the 8.8 pinion is pointing just slightly below the t-case output. I took measurements of the drive line angles the best I could with a cheap angle finder and got the following:
Driveshaft angle: 23 degrees
Pinion angle: 13 degrees (measured on the 8.8 housing webbing)
Based on this it sounds like I would need an 8 degree shim to allow for the 2-3 degrees difference in angles. But then I had the thought that once you start changing the pinion angle, wouldn't it also affect the driveshaft angle at the same time and therefore require a smaller shim?
Side note: it drives down the road without any vibes the way it is now.
