madJeepJ10
- Aug 5, 2009
- Marion
i have a 4.0 Comanche i was wanting to know what do you use if you put the radeator behind the cab. plumbing wise thank you
http:// I wouldn't use pvc, its brittle so if it gets it its gonna break and hour stuck. It will also melt, get soft at high tempslol thank so i can use exalts pipe or dose it got to be specel. can it be pvc
Curious as to what to use also, seen a lot of people running it through the chassis tubing on buggies, what precautions are they taking to prevent this? Mine is in exhaust tubing and was that way when I bought it, I am wanting to change it also.Be careful using exhaust pipe. It will rust from the inside out and that rust may end up somewhere it shouldn't.
I've thought about using copper for this reason.
The Napa hose I had bought was HD 1.75 hose. It is a special order item I believe and I think I paid like 130$ for 20ft.@Naterade99 and @Brownsxj both did this in their Toyotas and ran some long sections of radiator hose from Napa that you can buy by the foot.
