rear waggy dana 44 disc brake swap
just enough
welcome
I've been told that it's pretty easy to swap the drums on a waggy 44 rear axle to disc brakes. Wondering if anyone here has done it and what parts were used.
I used A&A manufacturing weld on brackets with '92 s10 front calipers and 1989 chevy stepside front rotors. You want the rotors that are 1" thick not 1.5".
what I did in the past is to use a mechanical style line-lock. tie it in to the rear brake line. pump the brake pedal and flip the lever. the rear brakes stay locked, providing the calipers don't leak. not to used as a long time i'e' days at a time.
