GotWood
Sayer of Fact
- Jan 12, 2007
- Maiden, NC
Ok, I'm pretty sure the 4 banger in the yj is headed south quick. I have a lot of blow by into the air cleaner and it is kinda yellow and snot-like. The antifreeze is kinda brown. The throttle body is very oily. I know the ideal thing would be to drop a v-8 in and be done, but that is not an option due to funds (or lack there of). Best case would be putting on a new head gasket and that would fix the problem but I know it won't be that easy for me.
What would be the first steps in determining the extent of my problems and going forward. Compression Check? What will that tell me exactly? If I pull the head and have it magnafluxed, will that tell me most of what I need to know? The motor has 170k on it and it does still run, and it doesn't smoke but I need to fix it right but don't want to go through the trouble of half assing something that doesn't work.
What do you suggest?
