80chevy_shortman
- Jan 17, 2010
- siler city, nc
recently bought a rollin chassis 76 k5, so i went and had a fresh rebuild on a th350 i had, and mated it to a np203. got a sbc 350 built .060 over, comp magnum cam that is rated at .470 lift with 1.5 rockers but i have 1.6 so im sure lift is now close to.500,aluminum heads 64cc 2.02 1.60 valves doubled valve springs, long tube headers, edelbrock performer intake, 600 holley vacuum secondaries, and msd street fire distributor. all out timing (2500-3000)rpm with dist vacuum unplugged is set at 35 and initial was like 16 i believe. cam is pretty lopey. problem is when i try to wot or open 4 barrels the truck starts stuttering and bucking like timing is off or its skipping. note that all engine parts are brand new never used besides block and carb which is rebulit. now with such a cam i should have used a bigger stall. but i used a new factory stall convertor and truck is factory geared 3.08. could this stock stall and such a high gear cause this problem maybe like its puttin a hell of a load on the engine tryin to move this ole heavy chevy. i plan on regearing soon waitin on some more cash flow first, any ideas r appreciated????
