Recovery Gear
dr_freeze
Resident of Planet Earth
Raleigh, NC
In my post regarding wheeling at URE, a couple of people suggested that the first thing that should be done in getting ready to go wheeling is to load up with some basic recovery gear. I'd be interested in hearing others opinions on what would be included in a list of 'basic recovery gear'.
As always, any suggestions or advice will be greatly appreciated.
Regards,
Mark.
1st of all, have tow points on your vehicle! Jerk strap, gloves,fire extinguisher, first aid kit. These come to mind real quick.
Recovery gear is a wide spread area. You could venture as far as safety stuff like fire extinguishers, wheel chocks, etc etc. It really depends on your budget, but here are some items/explanations etc:
Bare Minimum:
1x Tow Strap, with loop ends: Hooks can be dangerous of course, so most opt for a strap with loop ends. You can get the run of the mill strap 20' or 30' from Wal-Mart. Or you can go for a little bit more $$4 and get a brand name strap that is a little bit more heavy duty.
Recommended:
Gloves: Especially if you will be using a winch these come in handy.
1x Tow Strap, with Loop Ends: Covered Above
1x Tow Strap, with hook ends: There are jobs and situations that call for hooks. Especially when the vehicle doesn't have the greatest recovery points. Its always a must to have one, and again they sell them at Wal-Mart
Jack: A high lift jack is preferred but any kind of jack can be adapted for recovery. A floor jack and a piece of wood to spread the weight can even be used.
Shovel/Pick Tool: At Uwharrie this may not be as prudent because of the hard packed clay, but anywhere there is soft mud this is essential. Get a flat tire or stuck in the mud and you will wish you had one.
Above and Beyond (Winches etc included):
D-Ring: I would put this in the recommended but usually people have these on their bumper anyway. Even if you don't have a "d-ring" attachment spot on your bumper, it can help attach straps in other situations.
Snatch Strap: Think of a rubber band to put it very simply. It helps greatly in recovery if you are planning to wheel in the deep gooey stuff.
Snatch Blocks/Tree Savers etc: If you don't have a winch these are not as common. But if you do have a winch these are key items to have.
Come-a-long: I thought about putting this in the recommended but its a tiny bit beyond that. Again if you wheel alone, or where you might not be able to get a vehicle/strap this is a must. It also helps in loading disabled vehicles onto trailers.
And a full size spare tire. Also, your tow strap should not have metal hooks on it, just loops on both ends. Search around, there was a thread not too long ago where people listed out in detail what they carry in their trail rigs.
Duane
Completely agree, saved me from being stuck on a trail at 2:00(night crawling at URE) in the morning. A poor man winch is def nice to have, just be prepared to put in some work.
Eli covers the basics...but Id move d rings to must.
You have a tow strap with loop ends, how do you connect it?
it is not designed to be a choker...D rings to connect it.
I f you have a Hi-Lift jack, that can double as a come-along. Not as easy to use as such, and you can only go a couple feet at a time, but if space/$$ is limited, it is a reasonable option.
