Will scout D30 gears work in a CJ D30?
Basically I need to get 3.73 in my CJ to match my D44 rear. I've found a scout D30 with 3.73s. Is there a possibility of being able to avoid some of the trickier parts of regearing by using the carrier et all from the scout D30? What parts should I order?
Also, I want to put a spool in the D44. What's the downside to the mini spool. I realize a full spool is most likely stronger, but how much stronger?
