PAT Ventures
- Sep 21, 2009
- Wentworth, NC
I am going to be adding a remote atf filter when I add a remote cooler. I am struggling as to whether leave a screen filter in the sump or rip it out. What says nc4x4?
I would leave it in the pan. You want the fluid to be filtered immediately before it goes in. Look at what is on the magnet in the bottom of the pan.
If any particles come off the clutches, they fall into the pan with returning food from the trans internals, then it gets immediately ingested and fed straight to the pump without a filter. Leave it in and save having to drop the pan.
Fluid. Auto correct? Auto incorrect.There's your problem. You have food in your transmission.
If any particles come off the clutches, they fall into the pan with returning fluid from the trans internals, then it gets immediately ingested and fed straight to the pump without a filter. Leave it in and save having to drop the pan.
What do you gain by removing the filter from the pan?
The filter also acts as a pickup tube in most cases...so if you remove it, it seems like it would be far more likely to starve the transmission for fluid. If you starve it, I don't care how many filters you have, it's gunna shit the bed.
