Removing a 3" body lift?
Speed Freak
Member
High Point
I bought my jeep with a 3" body lift so I am unsure of all the parts to remove. I know the 3" pucks and the exhaust hanger. Is there anything esle I soulnd be looking for?
Thanks
Guy
Shifter linkage could have been adjusted or had an adapter added to it to try to stop binding.
Are those Hydraulic Clutch? Took a 3" BL out of my CJ and had to adjust my Mechanical Linkage for my clutch.
Also, Gas Filler and Breather hoses will likely need to be shortened.
Watch your Radiator Fan Shroud incase it has been moved to compensate for the BL.
brake lines, fuel lines, vent hoses, fuel filler, fan shroud, wiring. the list goes on. Many things are attached to both the body and frame and they all will need to be looked at.
