removing front axle
GotWood
Sayer of Fact
Maiden, NC
I broke the inner intermediat shaft in a d-30. What is the trick to getting the shaft out of the lock-rite, I can't even see the c-clips in the carrier.
right you are!! kinda of an easy fix once I got going on it. Thanks!
No c-clip. Front is a full floater. Should slide right out once you pull the hub.
Is it possible the spline end job a bit jammed when the shaft broke?
Sounds like and excuse for a chromo shaft upgrade.
I did mine when the vacuum diaphragm rusted through. No regret. Beefy suckers with 760X u-joints.
