Removing hubs on f250
GreenGrandsurf
Burgaw,Nc
ive been working on my axles trying to change out some ujoints and replace the lock outs. So i have 77.5 hp 44 from an f250. im having trouble getting all the stock lock out hub out to get to the spindle nuts. Ive got both rings out one from the shaft and the other the outer part of the hub. Ive also gotten the part out the outer allen head screws go into as well as the part that depresses the hub but i cant get the "body" of the hub out. Ive read to tap top bottom left right and it will eventually come but ive had no luck.
Screw the allens back into it and then push and pull. Crud tends to build up so you might use some carb cleaner around the outter edge.
i dont exactly know how this happened but that part has come out along with the part that is behind that, that depresses the body....so i guess im sol as far as screwing them back in, but ive got some ideas im going to start soaking it with some stuff and get something behind it and start pulling from every direction...BTW this mans brake kits are awesome and super easy to install i really like the way mine look
