RatLabGuy
- May 18, 2005
- Churchville, MD
The small bathroom attached our bedroom has a stand--up shower in it. It's the typical full 60" x 30-something deep. It's 3 panels and a floor, as opposed to the single-piece style.
Unfortunately as some point there was a clog that cause the basin to overflow and water got under the floor in front and under it, and has rotted the subfloor. you can feel soft spots when standing in it, and it has caused the plastic basin to crack in a few places (further allowing more water uinderneath which I'm accelerated he softness.
So unfortunately, I have to pull at least the floor pan out and the bathroom floor and replace it. But I'm assuming there is no way to get out just the bottom pan, all the panels have to come out too, right?
The plastic panels have drywall right up against them, both above around the top, and in front. Making in more fun the bottom half of the walls have wainscoting, also up against the plastic edge.
The real question is - is there any way to get this thing out w/o destroying the drywall, and that wainscoting, that is around it?
The videos I've watched of these panel installs seems they usually have a lip around them that goes against the studs, and the drywall then covers the lip. Is that always the case?
Patching and taping in DW sucks enough, but removing the whole panel of wainscoting will be a major pain b/c of window/door trim it goes behind etc. The whole project goes from "just replacing a shower floor pan" to "complete demo of almost all the walls". ugh.
