foreman1063
- Jul 11, 2005
- Raleigh
I have an 88 Comanche, 4.0l with 230,000 miles on the clock.
The thing runs like a top until it gets hot. When the ambient temp is high and the motor is at normal operating temp, it runs really rough at idle. Also, when you shut it off and try to restart, it can be very difficult. It cranks and cranks until it finally starts to fire with some pedal finesse. Again runs really rough at first until revved for a few seconds. At this point it still idles like crap until it cools down. Almost acts like it flooding when warm.
What I've done so far: New timing chain, new distributor, new plugs, rebuilt fuel injectors, Fuel pressure check appears to be normal, replaced cps, MAP sensor and coil with units from another MJ and condition remained the same, Adjusted TPS.
Any ideas would be appreciated as this truck runs great otherwise and would make a good daily driver if I could resolve this issue. Someone mentioned replacing the 02 sensor but I'd rather not start throwing parts at the problem without justification.
John
John
