Mac5005
- Oct 19, 2005
- Rocky Mount
So, Ive been searching, and searching and searching....and haven't found much, and what I have found is very conflicting.
Here is what i'm trying to do.
I have a 91 YJ with the 4.0. The engine has 60 lbs of compression on cylinders 2-5. Cyl #1 has 15 lbs, and cyl #6 has 45lbs. I am wanting to swap longblocks to get this jeep running/driving, and giving me a spare HO longblock to rebuild in the future as time/money allows.
I am looking at buying a 89 XJ engine, and only using the longblock, to replace the bad longblock currently in the YJ. Ideally I would bolt the 91 intake/exhaust, accessories, and mounts all on the 89 longblock, and i'm good.
I know the ports on the 7120 head are raised .125 over the head on the renix style head ports( 89 XJ), and that would only cause the airflow and performance to suffer, due to the mismatched head/intake combo. That does not concern me with this jeep and its purpose.
Will the HO intake bolt on the Renix head?
Will the HO exh manifold bolt on Renix head?
Will the HO water pump and accessories bolt on the renix engine?
Are the motor mounts bosses the same on both blocks?
Any and all info is appreciated.
Thanks,
Scott
Thanks,
Scott
