paulevans76
- Mar 21, 2005
- York, SC
Currently trying to reconfig my front suspension (Y-link radius arm) to lower it a few inches and maintain as much uptravel as possible. Part of what I'll need to do is relocate my panhard mounts. Right now the panhard and drag link are about as lined up as they could be, so anything I do about the panhard I'll have to mirror in some way to the drag link.
Notice the current uptravel limiting location of the axle side panhard mount:
The frame side:
I'm going to need to move the axle side panhard mount down somewhere where the tie rod would probably currently interfere - maybe lower on the front of the housing between the coil bucket and the diff? I'm sure it will probably end up needing a bend or two. I wish I could package it behind the axle, but my oil pan is in the way. Unless I put it WAY behind it
That brings it steering. Notice in that shot above that my steering arm and the current high steer arm are pretty well sized together.
So regarding steering, there's only a few ways to go:
1 - Y link steering to the stock knuckle location - I think I'd lose steering angle, as the stock arm looks a few inches longer. Moving to that location would probably provide enough room to mount the panhard lower on the housing though.
2 - Try to squeeze the panhard mount lower on the housing while leaving the steering as is, and then raise the upper panhard mount to match the angle - which I think would be great, but the first part looks like it's probably not possible:
3 - Maybe I can switch to a crossover setup where I run the drag link to the highsteer arm, perhaps with an offset tie rod end to give some extra room? Then run the tie rod in the stock knuckle location, and raise the frame side pahnhard mount to match the angle?
4 - leaf it and no more panhard!
Am I missing any other ways to set this up? I drive this pile to the trail still and would like to maintain that as long as I can, so hydraulic is out.
Thanks for any feedback/ideas.
Bonus fun: I believe I'll also get to fab up new motor mounts to get them out of the way of the uppers when I lower it. Was looking at a generic LS motor mount swap kit with a sleeved bushing/tabs/tube, and just drill the engine side plates for my motor mount bolt pattern
The frame side:
