Barnes 4wd
- Aug 6, 2007
- Etowah NC
Introducing our new Jeep Wrangler TJ heavy duty rear frame coil spring brackets. They are a direct replacements for your factory mounts. If you have rusted brackets, damaged brackets, or are looking to use TJ coil springs on your next project this is the bracket you need. This coil spring mount is designed to go in the same location as your factory bracket. The brackets are manufactured from 1/4" steel, shipped bare, welding required, and are sold in pairs. Applications: 1997-2006 Jeep TJ Wrangler.
VIEW PRODUCT LISTING
