Replacing a camper roof. Anyone ever done it?
RHSCTJ
ROCK HILL, SC
My neighbor is moving and offered me a camper. It's a bumper pull probably about 20 feet. Only (major) problem I know of is it needs a new roof. Assuming everything else is in working order I plan to replace it myself.
Calling on the infinite wisdom of nc4x4 for tips, tricks, and suggestions.
I've replaced a bunch, it will take 3 good days to do if you don't have to replace any wood so you need a place to do it that is dry.
Day 1: take all accessories and trim off roof and peel old rubber off. Wood underneath will be sticky from the old glue and will want to stick to your shoes so limit walking on the wood as much as possible.
Day 2: assuming no new wood is needed. Use a paint roller to spread glue out start at the front making sure you get the rubber tucked under the front cap nice and secure. Don't cut out for a/c or vent holes until day 3. Check for trash and splinters sticking up as you go before you roll the rubber onto the wood. While the glue dries clean the old rubber and sealant from your trim.
Day 3: glue should be dry enough to walk on. If not, wait longer. Put everything back on the roof and seal around everything.
