replacing cab flooring
DirtyD803
I need to replace the flooring in the cab of my K5, I know you can buy the left side and right side, but i also need to replace the center also. is there a place to buy all of it? i've looked on LMC but they sell the left and right side...
it will prob be cheaper and more sturdy to weld in some sheet metal or have someone fab something up. just my .02
Most of the sheet metal I've seen that's cheap...is! Good pans will cost you some bucks, one of the neat tricks for the tunnel, (shaping metal in complex shapes can be very hard), buy a cheap wheel-barrow and use it, cut it down weld it together how you need it. Get some good 14 gauge metal and fab it up for the floors (good sheet metal shop can help).
Chris
I just cut out where the rust was in mine and got some sheet metal and beat it real good with a hammer to somewhat fit the shape i needed it. The only trouble I ran into was that I had to cut out the holes where my driver side seat mounts to. When I put the new sheet in I did not have it lined up perfect and now my seats will not go in. No worries tho cause soon some seats are gonna be mounted to a cage
