replacing master cylinder 04 f150
YotaOnRocks
Madison
I am going to replace my father in laws master cylinder on his 04 f150 tomorrow. I have never replaced one on a vehicle with abs. Is there anything that needs to be done different with it?
No. Just bench bleed. I usually then bleed the lines at the master by cracking them loose just like you would a bleeder. You can then follow it up by bleeding at the wheels for good measure. As long as the abs doesn't command on the fluid will just pass through it.
