mbalbritton
- Mar 22, 2005
- Orlando, FL
Any good tips or tricks to replacing the CPS on an XJ 4.0?
Best done with laying on the ground behind the drivers front tire, get lots of extensions (12", 6", 3") and the universal wobbler socket. Duct tape the wobbler socket so it flexes a little but doesn't totally flop around. I can't remember if I use the 1/4" drive or 3/8", its tight. There are different versions of the kickdown bracket on the side of the AW4, one of them gets in the way. You can "shoot the gap" with all the ratchet extensions right along the flywheel housing if the wrong AW4 bracket isn't in the way.
I think the 2 bolts are 12pt. Don't drop them in the bellhsg. They are special shoulder bolts so you don't want to lose them. First time is a learning experience, you'll probably say fawk this and try it from above, realize you need 3 more wrist joints between your elbow and hand, then crawl back underneath and git r dun.
A rubber o ring on the swivel works better than tape. Holds the socket and keeps full movement...Best done with laying on the ground behind the drivers front tire, get lots of extensions (12", 6", 3") and the universal wobbler socket. Duct tape the wobbler socket so it flexes a little but doesn't totally flop around. I can't remember if I use the 1/4" drive or 3/8", its tight. There are different versions of the kickdown bracket on the side of the AW4, one of them gets in the way. You can "shoot the gap" with all the ratchet extensions right along the flywheel housing if the wrong AW4 bracket isn't in the way.
Damn it, those notes are for a ZJ. Anyone around Trinity have a long ass 3/8" drive extension I could borrow?
