Chuckman
- Oct 9, 2005
- Huntersville
I have been collecting parts for a resto mod 2A. I have been accumulating parts that were available,vintage hop-ups and cheap. Background: I drive my GPW all day on the weekends and most nights after I get home in the spring/summr. Which is fun in Charlotte but in Boone it doesnt have enough motor/brakes to be fun or safe up there. So I am going to build a resto modded 2A specifically for the Mtns (good motor/brakes) and light wheeling (URE). But mostly to build a sleeper Willys with the best of everything that was vintage available. Just a 'better' Willys. Not too wild, but very very solid and capable, yet look completely stock.
Planning on keeping the 2A frame and gusseting/boxing it but leaving it to flex in the frame as it was designed to do. I got a dauntless v6 off the board with matching radiator so I will keep that. Going with a SM465/D300 short output combo with Novak adapter. Then I am having a set of tall-gear narrow track CJ axles with 11" fronts and Moser single rear shafts made up (the low in the 465/300 will let it crawl but the tall gears will keep it roadhappy). Will run a vintage 30" tire on the 16" early CJ wheels. I plan on clocking the D300 into the pass seat tool box so it should be flat on belly. Will add power brakes, but will keep manual steering. Will put in a cage, but only a 'sport' design but mounted down to the frame. I will 'possibly' build a set of wide track axles with lockers if I ever decide to really beat on it but for now, I plan on the narrow tracks. Will sink a 8274 between the front frame rails. Probably going to use hydraulic external master due to frame flex.
what would you do different?
