UncleWillie
Rarely serious.
- Dec 29, 2010
- Vale
Well after oral surgery that left me with 9 bottom teeth. ( have a new aftermarket set on order LOL) I finally got back to tinkering with the LUV.
For those who missed my introduction I will give a short rundown.
About 2 months ago I got a call to pick up a truck or scrap. When I got there it was an 81 Luv 4x4 mikado that had been sitting for about 7 years.
Free Umbrella LOL
I brought it home and put in a good battery and poured gas in the carb and it started. The electric fuel pump was shot so I borrowed one from a buddy (between the two of us we have about anything you would ever need for a vehicle) and got it running. Drove it a bit on some back country roads and played with it in the mud and decided it was worth keeping. Even on bald tires it ran through spots my heavy 4wd Suburban sinks in. It pulled so well I was having trouble deciding if the 4wd worked or not. Finally had the wife drive it in to the mud and floor it while I watched from a distance.
Here is the wife driving it for the first time.
http://www.youtube.com/watch?v=dzaiAhN2lqw&feature=player_profilepage
Initially it wanted to overheat after about 20 minutes of driving, but after a couple of heat and cool cycles it stopped. I am guessing something congealed in the cooling system during dormancy.
I bought an electric fuel pump and made an ugly mounting bracket out of scrap metal and hooked it up. Truck starts perfect after being pumped 5 times. Runs great on the old long dormant spark plugs.
The turn signals started working after driving it about 30 minutes. I guess something was corroded from sitting so long. It starts perfect when it is cold. When it heats up it wont start anymore. I thought it was a bad battery and I replaced it, but it is still doing it. I am going to pull the starter and have it rebuilt. Good thing the little booger is light enough to push.
The alternator seems to be weak. The headlights are super dim. With the headlights on the turn signals wont work, nor will the blower. So the starter will be bundled off to the shop with the starter. While I have it apart I am going to check all the grounds and connectors for corrosion. Does anyone know of a higher output alt that is a direct bolt in for it? I have a few plans that will need more power.
It needs a brake booster. When I first drive it I thought it had manual brakes. Took another look under the hood and behold a brake booster. It stops fine it is just a bit hard on my bad knee.
Other things to address
Tune up, oil change, and fluid flush
New tires – possibly on 15 inch steel Trooper rims
The passengers side interior door handle needs to be replaced.
The glove box door needs supports.
Radio needs to be replaced with a working one.
Parking brake cable needs to be installed.
Fix back-up lights
Fix Hazard lights
Find seat cover before the factory one disintegrates completely
Find less cancerous body.
Oh yeah also need to fix the fang on the front skid plate where the PO got it hung on something.
Free Umbrella LOL
Fix back-up lights
Fix Hazard lights
