peewee
- Jun 28, 2008
- Stokesdale
So I have 2010 Silverado cc 4x4 4.8 flex fuel. I just took it in to the stealersship for the 2nd time becaulse its calculated ethanol percentage is way off. I don't use ethanol so it should never be over 10% but the computer shows 60% or more. This causes it to run weak, bad mpg and throw rich cel codes. Until 2013 Chevy didn't use a fuel composition sensor so the percentage is determined by mass air sensor, timing advance and o2 sensor. So here is the question. My understanding of an aftermarket programmer is that it will only change the parameters of the factory program. Is this correct? If I send the computer off to be programmed is this similar to what a programmer would do? Does anyone know if there is a way to shut the flex fuel part of the program off?
