ManglerYJ
- Mar 20, 2005
- Lexington, NC
So I have a 1972 Super Beetle that I'm hoping to get a little more ventilation out of at low speeds. It came from the factory with a 2 speed "fresh air" fan that no longer works (they were crap from the factory from what I understand). I have two PC case fans that fit nicely 1 where the busted dash speaker was and the other behind the screen on the other side of the steering wheel. The wiring on the beetle comes from a control knob on the dash and has two detents, one for each lead that comes from the switch and to a lead on the fan. There is also a ground wire. My hope is to be able to use the first wire to power one fan and the second wire to power both of them, sort of a "low-high" setting. Basically, the switch has 12 volts in and two 12 volts out as opposed to a rheostat (I think that's what it's called) how most other fan motors will run.
Is there an easy way to run one fan on the low speed wire and both fans off the high speed wire? Am I making this more complicated than it needs to be?
