I'd say the plugs were the main problem. Also wondering, for all & anyone, that pours whatever, into the carb? Did you pour it down the throat? If so, probably 98% went straight into the intake. Not the carb. I had the top off the carb, with the float out [optional] to wipe out the bowl. Besides pouring the bowl with cleaner, I pulled the full line at the fuel pump, inserted the line into the bottle, & spun the engine over. Made sure it pumped the cleaner through the line, needle & seat. Did any get into the jet? Not sure. But before I had opened up the carb, with the fuel line pulled, I cranked the engine & let it run a minute off the bottle. Then let it sit overnight. When That didn't fix it, Then I pulled the top of the carb, for more service. I think a piece of grit had gotten in the jet, & wasn't dissolving. After probing everything with tip cleaners, it seemed to be fixed. Had no problem since, & have mowed about 5-6 hours now.
