ring gear question
Money Shot
Jacksonville
i broke a few teath off my ring gear and my pinion is fine. can i put a new ring gear on with out having to replace the pinion or will i have to replace the pinion???
Replace both at the same time, cause the gears are lapped to match eachother when they were new.
youll def be better off in the long run.
More importantly what manufacturer made the gears and were they installed correctly? Just curious if it was cheap import gears
