Damage
- Nov 25, 2011
- Melbourne, Australia
Hi from Down Under,
I've purchaced an F350 to start a buggy build and want to end up with something like the Atena style buggys. Just a simple cage buggy with hydro steer and coilovers, 4 link front and rear. The donor F350 is a '94 single rear with HP D60 front, Sterling 10.25 rear,(4.1's I think) Auto E4OD, BW T/C, 460 Gas. I will probably manualize the trans. Terrain is similar to what I see at Morris Mountain, long steep hils with rocks and clay.
My questions are:
*If I invest in some Chromo axles for the front and beef it up a bit, what size tyres can I get away with? I would like to run up to 44inch.
*Am I better off swaping out the T/C for an NP type or will the BW T/C do the job?
* Should I go for a T400 with NP straight up and get rid of the E4OD and BW?
*What size rodends will suit for the 4 link?
I want to try to avoid building the frame then modifing it later if it doesn't work.
Any help would be great. Build will start next year when I get all the bits together.
My questions are:
