Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
well i think itd be alotta force on those bolts... cuz it looks that the adapter is bolted on using the hub bolts... deff be the weak link on the axle
plus since it bolts to the flange botls, it wouldnt matter whether the hubs were in or out, itd still be the same width, like 80" WMS or so
also you might find that being that wide may give you alotta hassle on trails, and while turning
True it will be realkly wide and probably harder to turn, buuuut i just cant afford a set of rockwell rims right now and the more people I talk to the worse the whole "weld in you own centers" thing sounds, and once again $60 a set . . . .
I mean eventually I'm gonna up my tire size and when i do that I will probably go to rockwell rims since I'll need at least 20's anyway.
But thats a good ways down the road.
As much trading and swapping as you do, I can't see why you're going to try to go the 8 lug route...
