rockingham dragway july 23rd
broncomania
ASHEBORO,NC.
if anyone wants to go see some good fast street cars please come out and support my racing series on july 23rd at "the rock" i would really appreciate it. thanks.
WINNER PAYOUT UPDATE BY MAC-FAB PERFORMANCE BEADLOCKS:RS EXTRA $500.00,
X275 EXTRA $1,000.00 , ODR EXTRA $500.00
$125.00 for best 60ft in eliminations for 275rs & x275 sponsored by ultimate converter concepts.
275RS RULES > http://ndrra.com/forum/index.php?topic=1118.0
X275 RULES > http://ndrra.com/forum/index.php?topic=1069.0
ODR RULES >
BODY: The car must retain its original appearance, profiles, and dimensions. Factory roof and quarter panels must be used. Aftermarket fiberglass replacement panels
are limited to hood, front fenders, doors, decklids, and bumpers only. All front ends must be of factory dimensions and cannot be stretched. Aftermarket wings and spoilers
are permitted. Complete stock appearing front and rear bumpers are required. Forward facing hood scoops are permitted.
INTERIOR: Factory appearing dashboard, door panels, and driver seat is required. Aftermarket steering column is permitted.
WINDSHIELD/WINDOWS: OEM glass or lexan windows are permitted.
CHASSIS: Complete stock firewall in stock location is required (firewall may be notched for clearance). Front core support may be modified or removed. Aftermarket bolt-on replacement front K-members are allowed
(front shocks bolted to K-member must be in factory location).
ENGINE: Small block or big block engines allowed with any deck height permitted.
TURBOCHARGERS: Any size single turbocharger is permitted. Twin Turbochargers are limited to a maximum inlet opening of 94mm. Any type intercooler is permitted.
Cannot combine with nitrous oxide except on 2-rotor, 4-cylinder, and 6-cylinder cars.
SUPERCHARGERS: Any type intercooler is permitted. Cannot combine with nitrous oxide. Roots or centrifugal superchargers permitted, no screw blowers.
NITROUS OXIDE: Any type multi-stage nitrous system is permitted.
TRANSMISSION: Any style automatic transmission allowed. Turbocharged and Supercharged cars with converter driven planetary transmissions are limited to a 2-speed.
Nitrous Injected cars with converter driven planetary transmissions are limited to a 3-speed. No clutchless manual transmissions.
INDUCTION: Any type induction is permitted.
OILING SYSTEM: Dry sumps are permitted on all cars.
EXHAUST: Mufflers or inserts are required on all cars except for turbo cars. Exhaust may exit underneath car or out the front fenders.
FUEL: Gasoline or alcohol is permitted on all cars.
STREET EQUIPMENT: Functional headlights, taillights and brake lights required.
SUSPENSION: Any style rear suspension is permitted. Wheelie bars are prohibited on all cars. Aftermarket direct replacement components such as: front control arms, rear
control arms, front coil over shocks, and rear coil over shocks are permitted. Aftermarket rack and pinion steering allowed. Bolt-on or welded sub-frame connectors, rear sway
bars, are permitted on all cars.
TIRES: Maximum size radial tire is 315/60/15.
Minimum Weights: All minimum weights include the driver.
Nitrous Injected (small block) 2500 lbs.
Nitrous Injected (big block) 2800 lbs.
Single Turbocharger (6-cylinder) 2800 lbs.
Twin Turbochargers (6-cylinder) 2900 lbs.
Single Supercharger or Turbocharger (small block) 3000 lbs.
Twin Superchargers or Turbochargers (small block) 3100 lbs.
Single Supercharger or Turbocharger (big block) 3200 lbs.
Twin Superchargers or Turbochargers (big block) 3350 lbs.
Twin Turbochargers (10-cylinder) 3350 lbs.
this is an NDRRA / MAC-FAB points race.
http://www.yellowbullet.com/forum/showthread.php?t=379972
