SSWaters
Old Member
- Mar 22, 2005
- Kannapolis
Feb 10, 2012 Show in original location
So George G. came over to the house and got me thinking about front disc again, this is my after work brainstorming.
It would be "hub out only".
If you wanted to run a larger outside diameter disc just make the caliper bracket taller accordingly.
Will probably counter sink the spacer to hub mount bolts or use flush heads. Kind'a close to caliper like this but it was my first try. I guess you could weld this but I don't like welding hot roll DOM to cast, even if you're certified to weld iconel underwater on the moon or magnesium on venus.
Would use high strength cap head bolts on the rotor to spacer mount, just didn't have any at work. Would safety wire those also, don't just trust locktite by itself on the rotors.
The rotor you have to grind a hair off each tang to slide it down on the hub (1/16" to 1/8"). Don't pay any attention to my scribbling on it.
The spacer is 7 1/2" OD by 1/2" wall DOM, could not find find 6 3/8" ID Tube at an affordable price for the weekend warrior (found it, just not affordable). Will have to grind out little "moons" in the bottom to clear the stud shoulders.
Since I had to go with 6 1/2" ID I shimmed this hub center with 20 gauge plates, could use 18 or 22 gauge depending on your hub (I had bead blasted this one clean). 16 Gauge is way to tight, had to really beat in and got all jammed up. Would have went if I had ground the hub surface really smooth. Shim all the way around evenly before drilling hubs! Spacer bolts go through shims.
