- Mar 20, 2005
- Morganton NC
This is something I do not remember being addressed here in this forum.
1. How do you tell the difference in the U-joint vs the Big birfield type front Rockwell? Pictures would be good here.
2. Are there any differences in rear Rockwell's?
3. Are all Rockwell's the same ratio's
4. What are locker Choices? ie Detroit's, welded and so on. Prices are a plus here too.
5. Any Wheel info helpful
6. I know some use disc on all four corners others use only pinion brakes. Pro's? cons? and costs?
7. How much clearance is gained when you compare Rockwell's to Dana 60 or 14 bolt?
8. I have heard biggest obstacle in mounting the Front is the clearance of drive shaft and oil pan. How much lift do you need?
9. If you go with disk or no brakes on the corners can you still run 15" wheels and if so, what backspacing is required?
I know these are a lot of questions, and I am not planning this right now, but the thought has been in my head a while. Just curious as to what all I would need, costs and so on.
Thanks in advance
Thanks in advance
