Rough Country Lift Kits, Leveling Kits, Misc. Components
CCOR
Athens, GA
Rough Country Best Deal Guarantee!​
Call us for any of your Rough Country needs! Whether it is a complete lift kit or just pieces and parts to one.
Need Shocks, bumpers, winch plates, and much more!
Need a quote then just Post up your needs!
Thanks,
Bobby
CCOR
706-207-4140
Jeep JK, TJ, LJ, YJ, XJ, ZJ, WJ, MJ, CJ-8, CJ-7, CJ-6, CJ-5, CJ-2 Lift kits and accessories.
Chevy/GMC Truck Lift Kits
Dodge Truck Lift Kits
Nissan Lift Kits
Ford Lift Kits
Scout II Lift Kits
Hummer Lift Kits
Toyota
Rough Country Lifts, Leveling Kits, Components
PM, post up, or call us for the best pricing on the any of the items that are available from Rough Country!
Thanks,
Bobby
CCOR
706-207-4140
1973 - 1976 4wd Pickup / Blazer / Jimmy / Suburban 6" Suspension
Kit Contents:Front: Lifted leaf springs, raised steering arm, brake line relocation brackets, u-bolts, and hardware.
Rear: 4" lift blocks, add-a-leafs, u-bolts, and hardware.
Shocks: Includes (4) RC Hydro 8000 series shocks.
Option: Available with New rear leaf springs.
Notes:• Fits 73-76 models Only.• Extended brake lines are recommended.• Must know rear spring length. [52" or 56"]• If vehicle is equipped with a front sway-bar
- drop brackets are recommended.
• If vehicle is equipped with factory front quad shocks - add below.• If ordering system with 56" rear springs (129H), due to this kit's weight it MUST be shipped to a business address with freight truck unloading ability.
Specs:• Part #: 125H / 127H [blocks]• Part #: 126H / 128H [52" springs]• Part #: ------ / 129H [56" springs]• Install Time: 6 - 8 hours• Recommended Tire Size: 37x13.50
1973 - 1976 4wd Pickup / Blazer / Jimmy / Suburban 2" Suspension
Kit Contents:Front: Lifted leaf springs, brake line relocation brackets, u-bolts, and hardware.
Rear: 2" lift blocks, u-bolts, and hardware.
Notes:• Fits 73-76 models Only.• Must know rear spring length. [52" or 56"]• If vehicle is equipped with a front sway-bar
Specs:• Part #: 105H / 267H [blocks]• Part #: 185H / 186H [52" springs]• Part #: ------ / ------ [56" springs]• Install Time: 6 - 8 hours• Recommended Tire Size: 33x12.50
1977 - 1987 4wd Pickup / Blazer / Jimmy / Suburban 6" Suspension
Notes:• Fits 77-87 models Only.• Extended brake lines are recommended.• Must know rear spring length. [52" or 56"]• If vehicle is equipped with a front sway-bar
• If vehicle is equipped with factory front quad shocks - add below.• If ordering system with 56" rear springs (215H), due to this kit's weight it MUST be shipped to a business address with freight truck unloading ability.
Specs:• Part #: 155S / 160S [blocks]• Part #: 205S / 210H [52" springs]• Part #: ------ / 215H [56" springs]• Install Time: 6 - 8 hours• Recommended Tire Size: 37x13.50
1988 - 1991 4wd Blazer / Jimmy / Suburban 6" Suspension
Notes:• Fits 88-91 models Only.• Extended brake lines are recommended.• Must know rear spring length. [52" or 56"]• If vehicle is equipped with a front sway-bar
• If vehicle is equipped with factory front quad shocks - add below.• If ordering system with 56" rear springs (215-88-92H), due to this kit's weight it MUST be shipped to a business address with freight truck unloading ability.
Specs:• Part #: 155S / 160S [blocks]• Part #: 205S / 210-88-92H [52" springs]• Part #: ------ / 215-88-92H [56" springs]• Install Time: 6 - 8 hours• Recommended Tire Size: 37x13.50
Rough Country Lift Kits and Accessories
Call, PM, or Post up for super LOW prices on Rough Country lift kits and products!
Rough Country lifts currently available:
1978-1979 Full Size: 2.5" or 4" lift kits
1980-1996 Full Size Bronco: 2", 4", or 6" lift kits.
1980-96 Ford F-150 / Bronco 6" Suspension
Kit Contents:
Front: Lifted coil springs, radius arm drop brackets, I-beam drop brackets, and power steering pitman arm.
Includes FREE Single Steering Stabilizer!
Rear: 3" lift blocks, add-a-leafs and u-bolts
Shocks: Kit includes (4) Hydro 8000 shocks.
Option: Available with new rear leaf springs.
Notes:
• Trucks with factory quad shock option
- select quad shock box.
• Rear leaf spring option includes 4" rear leaf
springs w/2" blocks.
• Sway-bar drop brackets are required for trucks
equipped with front sway-bars.
Press:
• Featured in Off-Road magazine.
Specs:
• Part #: 470S [Kit]
• Part #: 525H [System]
• Wheel Backspacing: Factory
• Recommended Tire Size: 35x12.50
80-96 F-150 / Bronco 2.5" Suspension Kit
Includes:
Front coil springs, radius arm drop brackets, I-beam drop brackets, 4 RC Hydro 8000 series shocks, u-bolts, and option of 2" rear blocks or rear leaf springs.
Notes:
• Vehicle with factory quad shocks, select quad shock option of Hydro or Nitro.
• Rear leaf springs fit F150s Only.
Recommended Tire Size 32x11.50
1980-1996 4wd F150/Bronco 1.5" Leveling Suspension
Kit Contents:
Front leveling coil springs.
Benefits:
• 100% bolt-on installation.
• Increased ground clearance.
• Levels front of vehicle with the rear.
Specs:
• Install Time: 1 - 2 hours
• Recommended Tire Size: 32x11.50
78-79 Bronco 2.5" Suspension Kit:
Includes:
Front coil springs, 4 degree C-bushings, track bar drop bracket, 4 RC Hydro 8000 series shocks and rear blocks & u-bolts.
Notes:
Recommended Tire Size 33x12.50
78-79 4wd Bronco 4" Suspension
Kit Contents:
Front: Lifted coil springs, trac bar bracket, 7° C-bushings, and hardware.
Rear: 3" lift blocks & u-bolts.
[Available with New rear leaf springs]
Notes:
• Rear block kit replaces factory lift block.
• Rear spring kit retains factory lift block.
• Drop pitman arm is recommended for optimum turning
radius and drag link alignment.
• Pitman arm will not work if original arm has welded
ball joint on end.
Specs:
• Part #: 450H [blocks]
• Part #: 535H [springs]
• Install Time: 5 - 7 hours
How much on the 4in kit with the rear block, for a 91 Suburban 4x4 3/4ton. Should be part # 150S.
-Also a price on the 6in part # 155s
Thanks!
