I layed down some Rustoleum Clean Metal Primer on Fiberglass.
More of an experiment really. I have sanded the the fiberglass to with 150 paper on a DA Sander. I then washed it with dawn, then I wiped it down with paint thinner just to get everything off. I rolled it on fairly thin. Did not get 100% coverage probably close to 90%. I have also started to sand it with 220 on a sanding block. I get good dust with very little clumping on the paper excect when I sand off the runs. However, I can still take my fingernail and scrape it off pretty easy.
How can I really tell if this stuff had adhered to the fiberglass?
It has dried for 24 hrs and quite a bit of time in the direct sunlight.
Can says recoat time is 24 hours and I would have guess it would have completely set up by then. Of course is has been fairly humid the last 24 hours. It is not sticky or tacky at all.
