redneckjeep87
Landscaper Extroidanaire
- Oct 10, 2007
- Woodleaf, NC
Fighting my sammi currently. 1995 with 1.6 8v swap. Lost spark and fuel after a headgasket replacement. Tried a different coil first, didnt change anything. Had the computer repaired in case that was it, as the symtoms were pointing to it, had 3 swollen capacitors. When these certain capacitors go bad it caises a no spark condition which then causes the computer to shut down fuel. Still wont start.
With a spark tester, temporary lights on key on, then occasionaly lights on first and second revolution, then will stop. Checked wires coming to/from distributer, key on they are 12v, ground, then blank (signal) like supposed to but on crank they all ground. I am at a complete loss currently, any help would be greatly appreciated! Its over at a buddies shop, since mine is always overrun with work projects. I will be going over there this afternoon to do some more troubleshooting starting with new underhood grounds, battery, coil, distributer, engine, then a ground to computer and see where that leaves me.
If i cant get it figured out soon im going to find a way to shoehorn a sbc im the damn thing. Thanks in advance
