samurai 1.6l hood clearance
You can do a 1" body lift and clear it, use aftermarket motor mounts, or make brackets that move the back of the hood up out of aluminum. Body lift is the cheapest and most common. When you start messing with modifying the mounts, you get into issues with the fan in the fan shroud not lining up.
