ballou
- Jun 3, 2012
I've had many 4x4's all fullsize, customs and stocks, now i find myself in a pickle hoping you guys can help with some direction and advice. I picked up a partially modified 87 rust free clean title samurai in a local junk yard for 300.00. It has a spring over lift with 3in blocks on the back and add a springs in the front someone has put the drive shaft spacers on it and the factory shock on it are doing nothing, it is as stiff as a duece and a half in the supsension dept. it can easily clear 38's. The motor seems to have had alot of work done to it header, aftermarket head, snorked. Drive shafts were out of it when i saved it after instaling the shafts, and borrowing some 32" tires and wheels being it didn't have any, I put a hot battery in it and some sprayed some gas in the carb it cranked and ran!!! With out hesitation I took it for a road test it would haul ass for such a small 4 banger. Untill the rear end locked up, pulling the rear drive shaft into, and ripping the rubber mounts holding the transfer in, less than 2 miles from my home. The rearend is toast after closer look the rear axle housing was bent inward (diffcoverarea) and was putting pressure on the ring and pinion which had only alittle water and a lot of rust in it no oil! I hate not to do something with it with as little money i have in it being that everthing but the axles do not work. Now I have been holding out I have picked up a set of 34x10.50x17 super swamper LTB's with the warranty nipple's on them at same junk yard for 200.00 with matching 5x5.5x17x9 crome steel wheels for the sammy. Also picked up a 1978 Toyota 4x4 running and driving w/powersteering it is a rustbucket and has no title for 200.00. I need my shop back the sammy's on stand's in my shop. I need help to repair or to sell help!!!!!!!!!!!!!
