sas
countryboy
Member
concord
Have leaf springs hung but have no leaf purches for bolting frt SAS frt axle. And what frt brakes should be put on the rotors are smaller than original on the 94 sr5. Also will I need to have the frt. driveshaft streached? This is for a 94 sr5 with sas using an 85 4runner 8inch frt axle geared 572 frt and rear. 9inch suspesion lift with 38x12.50s on yota 15x8s. Then 3inch body lift after the swaps done. Also need to sell my big 79 bronco MAny extras done to it. Just that I dont drive it near enough. $5500 obo.
You'll have to fab spring hangers for the thing front and rear, you can use vented rotors of an older style land cruiser with calipers and pads off an '86 4runner v6. Odds are the front driveshaft will have to be lengthened, but you'll have to wait to do that till you get the alxe in there and can measure at full droop and compression on the suspension. And you might try putting the Bronco in the swap meet section.
drive shaft
for your driveshaft give us a shout... right off S. Main Street in Concord, in front of the DMV/ liscense office
UNIVERSAL AUTOMOTIVE 704-721-3319
*also if you need your gears installed/lockers/sliders, we do that also
"think u mean 5.71's... i would recommend 5.29's"
9" of lift:confused: for 38s....
anyways, good luck getting a front drive shaft in it without running dual cases, or a high pinion third. You are probably going to have to get the knuckles rotated so you can point the pinion up a good bit... just letting you know so you can put it in the budget.
Seth
Seth
yep thats a little tall for 38's.... but toy single joints will do,
notice the front driveshaft angle...worked fine for two years... only ripped the ear off of one joint on kodiak rock:driver:
more than 8" lift without a highpinion 3rd, or the knuckles turned...worked fine
also i kno this is a little tall... i have my flame suit on
