Lurch830
messin' with sasquatch
- Mar 1, 2007
- Albemarle, NC
My eventual plan is to go to 1-tons & I've got some questions that I'm wondering about...
The Plan:
Swap d44 for a ford kingpin d60
Keep current leaf springs in front (stock rears with add-a-leaf)
Swap h233b (stock axle) for a 14bolt
Keep current leaf springs in back (63" chevy 2WD leafs)
Swap d300 for a 2-speed atlas w/ parking brake kit
New drive shafts with 1350 U-joints everywhere
Chromoly axles for the d60
Chromoly stubs w/ stock inners for d60 spares
Stock spares for 14bolt (most likely will not need)
Gear both axles 5.38
Lock both axles (spool in rear, spartan in front)
Full hydro steering
Recentered H1s with 37" military tires
Questions:
Is there a downside to running a Stak instead of an Atlas? They are cheaper & I like the 3 gear option that Stak has while still having 'hard' linkages. Is it cheaper because you get what you pay for/bad craftsmanship, inferior materials, etc?
With the H1s, would cut-down rubber or PVC runflats be better? Rubber is cheaper than PVC through trail worthy fab, but I imagine getting the rubber out would be harder than PVC. If I got PVC, I was going to cut them like Billavista did to make installation/removal easier.
Any advice/input to offer?
The Plan:
Full hydro steering
Questions:
