Chuckman
- Oct 9, 2005
- Huntersville
so I finally killed another 700r4 in the sand last weekend. well its leaking and needs to come out for some loving and I might as well step up my game and replace it with cool stuff over the winter. Im running a '05 6.0 and tons, on 37's / 38's depending on what Im doing and I like a heavy foot. Ive got a bunch of D300's sitting around that I got cheap since I started breaking them in half so I know they will die behind a solid trans. so since Im towing my GPW around quite a bit and not wheeling at all much anymore, that a nv4500 would be a great fit for me. what I don't like is the 205 due to the gearing but it will be bulletproof. so.... what do I look for in a donor? I know about the low first gear models, but will they command a premium? and since Im 4.56:1 and spinning 'short' tires, will I care/miss the deeper 1st gear? Im already programmed the chip to be a manual trans, so no issue there. will I need to change out starters? what are swap options for the clutch master? will a slave cyl come on the trans or the bellhousing? can I pick up a 2wd trans and put on a 4x4 adapter easily/cheaply? what else am I missing? I don't want a doubler, but would like options on cases. Im running a cj7 so overall length can be an issue. what are the pitfalls and little things that add up and make this a nightmare?
