seafoam in a 4.0
stockzjwnc
Member
wnc
can i pour seafoam straight into my intake and does it help at all?
Seafoam is great stuff. You can pour it into the gas tank, engine crankcase, and in throttle bidy as long as the engine is running, rpm's are way up, and you pour it in a little at a time.
pull your vaccuum line off your brake booster and let it pull into your intake you will have to have someone inside to keep the throttle up until you get about a quarter of the can in then shut it off for 15 mins then start back and watch the smoke show
Mopar Combustion Chamber Cleaner does the same thing and is also available at your local Chrysler/Jeep and Dodge dealer.
well i was advised to use magic marvel or somethin like that and i just put it in my gas
marvels mystery oil is good as well.....I havent found anything that de carbons as good as sea foam though, I run a decarb cycle once a year on the outboard and its amazing.
The MOPAR probably does well, but im sure it more expensive (what isnt from a dealer)and you can get SEAFOAM at AA, WalMart wherever.
Funny thing is now a days things are cheaper at the dealerships, granted the Mopar combustion chamber cleaner is probably more money. We have customers that shop around for brake jobs and other services and they come back because we are cheaper.
