moldman05
- Jan 27, 2006
- Rocky Mount NC
I bought a 54 Desoto hemi engine last spring at a car show. It would not turn so I pulled the plugs and poured in oil and trans fluid and let it soak. Today I pulled the pan, all the bearings look good, no water or rust just oil. Number 2 piston won't move. I tried more lubricant from the bottom of the cylinder, I heated piston from bottom with torch, beat every which way with blocks of wood, and tried turning the piston with connecting rod, but no movement. Any thoughts on what to do ? The engine is really clean on the inside and the bottom end has been rebuilt so I'd like to get it running without dissassembly and rebuild. Thanks for any help.
