VortecJeep
Powered by Uranium-235
- Aug 24, 2005
- Concord, NC
Just changed the water pump and serpentine on my 1996 ZJ (4.0, 195K miles). Now when the A/C kicks on at idle, it squeaks terribly. It does not squeak if the A/C compressor is not engaged or if I am running down the road.
Is the belt too tight or too loose? It doesn't have a spring loaded tensioner, you have to set the tension with a bolt.
