98zjstroker
- Oct 14, 2009
- concord nc
Ok so just installed the head on my 4.7 jeep stroker and trying to adjust the lifters to the correct spec. There are several videos I have found that talk about setting it to zero lash before torqueing it down to spec ( I have seen anywhere between 19-21 ft/lbs).
Other stuff I have read...including the instructions sent by howard performance cams which is what im using, after setting to zero lash if I have 7/16x20 adjuster nut (can someone please verify this is the right thread pitch), for every quarter turn the nut moves .0125". The specific lifters I am using require me to be set at .020-.025.
this means it needs a half turn to set to the proper preload. After I did this it was obviously not at the correct torqueing specs I have seen. to test it I ended up having to give it 1 and 1/2 more turns if I remember correctly to be at the correct torque.
everything I have found either says torque to spec or turn a half turn...….but neither mention the other one.
Is this because some are using the stock old lifters and others are doing a new install and need to set preload?
Do I need to first set preload (half turn) and then torque after that? would that not mess with the preload? I am so lost so please help and speak slowly cause my brain is fried.
