98zjstroker
- Oct 14, 2009
- concord nc
as said, no adjuster on the jeep 4.0. you can rotate (to base circle) so your not compressing the spring as you torque to 19ftlb. or you can just tighten them down evenly. both ways are fine, however you cannot tighten one all the way without running the one on the same bridge with it or your bent that bridge and the rocker wont ride correctly on the valve stem top.
your lifters need to be preloaded .020 to .060 max. Hence the pushrod checking tool.
This is where I am getting confused. you mention torqueing to 19ftlbs, which is what a bunch of videos and other online research says to do....but the instructions sent have no mention of this so I am lost. I set zero lash, then I used that calculation to add another half turn. this is suppose to put my right at .025 preload which was in the recommended adjustment. But this is far from 19ftlb. I tested it and I beleive it took another 3/4 to 1 and 1/2 turns to get it to 19ftlbs.
This is what is throwing me off. is this what you mean by both ways are fine? I can do either or?
