UTfball68
- Jul 18, 2008
- Granite Quarry
So fellas, I went to put the shift kit in the C6 in my Bronco. I bought the B&M Shift Improver kit. First let me say, I'm not a transmission guy and was completely lost and intimidated by this. Secondly, let me say the B&M instructions are garbage and even more confusing. Anyway, I drop the pan, and I realize I really need to install a drain plug. Next I pull the filter...done it before, so I'm a pro. Next I pull the valve body...still pretty easy.
Next I pull the valve body apart. Again, really easy, just be careful and slow in order not to lose any springs or check balls. Anyway, I drill the two holes as directed by B&M in the seperator plate. Then I put in all necessary hardware and reinstall any and all springs and check balls. The instructions were confusing as hell, but except for a couple pieces of hardware, it went back together the same way it came apart.
So now this is where I start having issues. I put the valve body back up, and apparently missed the 'gear selector pin' thing on the valve body. I didn't realize this until I went to put the Bronco in reverse, and all I had was drive. So I drop the pan again, I get that situated and button everything back up. Now at this time, some how my kick down gets lodged and won't allow me to give any throttle. It's literally like I have a rock under my gas pedal. And some how, I have something blocking my dip stick from going all the way in (no interference when I put the pan on). So I disconnect the kick down and say screw the dip stick...woo-hoo, works great...for a while.
BUT...
Now, some times it'll start in first and other times it'll start in second. Shifts are all great though. And I can manually upshift and down shift with no problems.
So my questions are:
-What did I do wrong that my transmission won't always start in first gear?
-And what in the hell could be hanging up the kickdown (or does it now need to be adjusted) and the dip stick?
BUT...
