Shop to mount H1 rims?
seed60
Mooresville, NC
Who can mount a set of 38"s on recentered H1 rims with pvc inserts? I have 2 brand new and 2 used, made in 2004, 38" TSL SXs.
Thanks,
Matt
They're very easy to do yourself. A few basic tools and you can be done in a couple hours. To get the insert in the tire just stand the insert up and then lay the tire across it perpendicular to the insert and push the tire down. Then use a couple pry bars and a rubber mallet to work the insert inside the tire. You can use soapy water to help lube it, but you probably won't need it.
Be happy to help you through your first ones. You'll see they aren't too bad to do!
^^My thoughts exactly.
Thanks for the offers and tips. Got googled up on it, found an air compressor, and was able to get most of them put together.
Glad you got them done. For future reference try stoutworx. They have a decent group of guys that work there and they support military/vets (why I shop there)
