redneckjeep87
Landscaper Extroidanaire
- Oct 10, 2007
- Woodleaf, NC
Okay im in the process of finishing up the exterior of my 18x40 shop, which means its time to really start on the inside. Which means running power.
I have a small subpanel im going to put in my shop which will be ran off of the main panel on the outside of my house about 100' away. The main panel on the outside comes off the meter(200 amp? ) then runs into the house via to the sub panel there. The well pump also comes off this panel via a double throw 20amp breaker. There is also a hottub that has a double throw 50amp breaker but it is not running currently do to needing some work.
The question i have is this....what size wire and breaker do i need to run from the main panel to the sub panel in the shop? I have space for 2 double throw breakers on the main panel.
I was planning a leg for dedicated 220 for welder and compressor and the other for outlets and lighting.
Or is this not the correct way to go about it? If not how should i power the sub panel in the shop.
Thanks in advance and hope I dont sound too ignorant of electrical. I have a decent knowledge but have never messed with wiring in panels.
